swapped intake now it won't start
Old Aug 10, 2002 | 11:58 AM
uidzer0_z28's Avatar
Hey guys,
I just swapped my intake from an edelbrock airgap to a weiand stealth, after getting it all put back together I go to start it and it just keeps cranking. It dosn't turn over at all. I checked the #1 plug to make sure there was a spark and it is there. Everynow and then the carb will spit up gas but it still dosn't turn over at all... any ideas???
Ben
Old Aug 10, 2002 | 12:27 PM
si_camaro's Avatar
Car: 85 Z28
Engine: LG4 modified
If you're getting a spark, and with changing only the intake, you're still getting compression, that leaves fuel. Have you checked the fuel line for blockage or contamination?
Another possibility is that you have the plug wires the wrong order. Assuming you removed them of course. The distributor end wire cover has the order printed on both sides, both different. Does on mine, anyway.
Old Aug 10, 2002 | 12:29 PM
hrm, I think it is getting fuel because if i look down the carb and pull the throttle back i can see fuel squirt down the primaries, I will recheck the plug wires again. = [
-Ben
Old Aug 10, 2002 | 01:16 PM
Hulk0202's Avatar
Dist. put in correctly?
Old Aug 10, 2002 | 02:15 PM
ede's Avatar
ede
yep recheck you timing and make sure the wires are run to the right plugs
Old Aug 10, 2002 | 03:17 PM
agh, i needed it anyway so i went up and got a new cap/rotor/coil/wires and installed them. Still nothing! i am pretty sure i have all the wires in properly, checked the spark again on the #1 plug and it looks good, is there a way to make sure I got the distributor in properly? It is flush with the intake and bolted down.
Old Aug 10, 2002 | 03:53 PM
Hulk0202's Avatar
You have to mark it and put it in the same way or it'll be off. Do a search on how to install one properly.
Old Aug 10, 2002 | 03:58 PM
yeah thats what I did = [ ...
Old Aug 10, 2002 | 07:38 PM
ah finnaly, reset the timing one more time and it went, now if i could only find out why it is sluggish
Frozer!!!
Jan 19, 2024 04:55 PM
midge54
Dec 27, 2019 04:14 PM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
mustangman65_79
Aug 8, 2015 12:07 PM
