i need a combo for a 350 to go low 13's
Old Aug 10, 2002 | 05:05 PM
83z28500ci's Avatar
any 1 have a combo to make a 350 go 13's in a 83 z28 with a th350 trans\3000 stall and 3.23 gears?
i want to keep the internals stock, has flattop pistons, 458\458 lift,218\218 dur @ 0.050 in. i would like to keep that cam in to. the motor is a reman from 70-74
what heads,intake,and carb should i go with? if i need a better cam what cam should i go with to.
thanx
Dan
Old Aug 10, 2002 | 09:24 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I'd get the Comp 268XE 477/480, just got mine in and love it. You'll need full exhaust if you don't already.
Weiand Stealth intake $110 in Summit idle-7k rpms or so.
Not sure on the heads, just something with high compression would work nicely.
Old Aug 12, 2002 | 09:21 AM
flyin89's Avatar
Since you asked don't order your cam until you pull the heads and verify flattop pistons! Now if you do have flattops the best combo would be vortech heads($450 prob.),RPM intake($175)and a 268 comp cam(this is actually a little small but the heads will only go 460 lift without machining). If you can afford to machine the heads or call Scoggin Dickey chev. and get a set for .550 lift then definitely go with the 274 extreme cam(I ran this combo with 3:73 gears,3000 stahl,750 DP,cutouts and slicks went 12:24@110 in MCSS) Remember you'll have to get self aligning rocker arms (most late model engines have them and centerbolt valve covers(pull them off a late model and have them cleaned). upside to all of this is you could make this thing LOOK stone stock with some effort(SLEEPER). You really should get some 3:73 gears being as a 3000 converter is still slipping at 23-2400 RPM at 60MPH(plus you'll love the Holeshot)
P.S. Cutouts are usually good for about 20 HP! I keep it quiet on the street (no cops just a very choppy idle) and open it up at the track!
Old Aug 12, 2002 | 01:44 PM
Low C1500's Avatar
Car: 89 Shortbox
Engine: 350 Vortec
He's right. I've got a similar setup, no complants! But If my motor was in a car I would go slightly bigger cam, say a 278/286 duration, or something like it.
Old Aug 12, 2002 | 03:36 PM
Odyssey's Avatar
A tried and true combo would be the Edelbrock RPM package. Which means the Edelbrock RPM cam, heads, intake and a carb. That will go mid 12s easily and it's really not expensive either.
Old Sep 4, 2002 | 04:14 AM
Harley83's Avatar
amen to that i couldnt agree with Odyssey more. that combo pushes 420 horses and can be a daily driver as well. i hear a lot of people down on that cam and it is really old and outdated but with that cam only a 2000 rpm stall is required cuz the powerband is 1500-6500! that would easily put you in the mid to low 12's provided with good traction.
Old Sep 4, 2002 | 05:54 PM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
I saw a big heavy chevy monte carlo run 12.6 with the RPM cam and my L31 Vortec heads... I also hear a lot of people talk trash on that old-*** cam but 12.6 in a full bodied Monte with bone stock vortecs is pretty impressive.
customblackbird
Aug 15, 2021 10:16 PM
theshackle
Sep 17, 2020 08:26 AM
Reborn756
Sep 4, 2015 03:42 AM
IMissMy86TA
Aug 31, 2015 08:40 PM
theurge
Aug 21, 2015 12:46 PM
