car loses spark after it worms up???
Old Sep 1, 2002 | 06:03 PM
Night Hawk 92's Avatar
I'm running out of ideas!!!
I changed the coil, ignition modual,and pick up coil.
I checked for power to the coil...its there.
I directly grounded the the coil to the batt.
Still after running for about 1min the car shuts off and wount run for about 4 hours!!!!
WHAT SHOULD I DO NEXT!!!
Old Sep 1, 2002 | 07:17 PM
ede's Avatar
ede
check the modual, doesn't really matter if you just replaced it, check it again when the problem develops.
Old Sep 2, 2002 | 04:49 PM
I will try that....the old one I pulled out tested ok cold and hot I just replaced it to eliminate any possibilities.
Old Sep 2, 2002 | 05:49 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Will it start if you squirt starting fluid into it? (Might not be an ignition problem at all...)
Old Sep 3, 2002 | 12:50 PM
The car does get fuel...I have a in line spark tester that will allow the car to run well checking for spark, after about a minute the spark just stops.
I tried grounding the distributor and the coil directly to the batt. along with the intake manifold just in case......still loses spark!!!
Old Sep 3, 2002 | 01:01 PM
ede's Avatar
ede
use a hair dryer or heat gun to warm it up, see if you can make it fail
Old Sep 3, 2002 | 06:00 PM
I will pull out the heat gun and give it a try....I will try anything at this point!
Old Sep 3, 2002 | 08:33 PM
BOTTLEDZ28's Avatar
Transmission: A4
this may be a long shot here but maybe heat is causing resistance is an ignition wire somwhere. have you done any modifitying to anything electrical at all on your car? does the car just shut off like turning the key off?
Old Sep 4, 2002 | 12:22 PM
Yes...the car just shut off like someone turned the key.
I had a crane cams booster box and coil, I went back to stock after all this started.
Well...you where write ede, I took the module off the car and checked it after the car wouldn't run. It was bad! I went out and picked up a new one (A/C Delco this time) and the car runs great. I guess that is what I get for buying a no name part the first time around.
Old Sep 4, 2002 | 12:24 PM
I almost forgot.....
THANKS FOR ALL THE HELP
Old Sep 4, 2002 | 12:35 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
NightHawk, when you replaced the module the first time, did you use the heat sink grease with it? If you don't use the grease, you'll overheat the module in no time. And, did you use the grease with the new module? If it didn't come with the stuff, you can buy a little tube of "heat sink grease" from Radio Shack for $5.
Old Sep 4, 2002 | 06:06 PM
Yea...I put it on both times. I have a large tube of it from carquest.
1992 Trans Am
May 10, 2023 07:19 PM
midge54
Dec 27, 2019 04:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
jharrison5
Aug 19, 2015 05:53 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
