Bad Feul Pump?
Old Aug 10, 2002 | 10:57 PM
fastredtruck's Avatar
Car: 88 gmc 1500
Engine: 496
Bad Feul Pump?
Just conveted form tbi to a holley street avenger 670 carb
i used the factory tbi pump and a mallary ignition regulator
when i turned the key the fuel preesure guage didnt move so i dissconnected the high pressure line and turned the key and nothing. The engine deosnt have to be running or craking to get feul pressue right
before i put the carb on i did some mods and it ran horrible it would bog under load and always run lean but i thought it was the tbi not keeping up with the mods thats why i went to the carb wich ill probally be much happier with so what do guys think is up with this and how can i test the pump without droppin the tank iwas also was thinking of the relay and i looked at the fuse and its cool. thanks
Old Aug 11, 2002 | 07:00 AM
ede's Avatar
ede
if you can put a FP gauge on it you'd know what you have for sure. seems odd the FP would fail while your were working on the engine. if you're running the supply line to a regulator an then the carb you should have 4-6 lbs. of preasure to the carb. quick and cheap check is to crack open a fitting before the regulator and fuel should spray out under preasure and not just give a little squirt and drip.
Old Aug 11, 2002 | 10:02 PM
Car: 88 gmc 1500
Engine: 496
TRACED IT TO A BAD GROUND WIRE
Glowsock
Jul 24, 2025 03:15 PM
mustangman65_79
Apr 14, 2017 05:37 PM
xxx3man`
Sep 23, 2015 10:37 PM
backtothe80s
Sep 5, 2015 12:39 AM
Winchester1094
Aug 18, 2015 10:23 AM
