i went from r-12 to 134
Old Aug 11, 2002 | 09:02 PM
bad@ss89camaro's Avatar
Car: 91 Z/28 convertible
i changed over my air over from r-12 to 134a the other day ind its only blowing out 60 degrees anything u guys suggest me to check out
Old Aug 11, 2002 | 09:21 PM
ronterry's Avatar
Car: '94 Corvette
Did you change the pressure switch?
R-134a requires more pressure to function properly, then R-12.
Did you have a vacuum pulled on the system?
If you have air in the system it's basically an uncompressible & reduces cooling capacity, and over works the compressor.
Ron
Old Aug 11, 2002 | 10:14 PM
where and whats the pressure switch
Grumpy
Jun 9, 2003 06:05 AM
Grumpy
Apr 7, 2003 08:23 AM
justadba
Aug 6, 2002 07:33 PM
George Khawahie
Jun 3, 2002 09:53 PM
