Strange coil issues
Old Aug 12, 2002 | 02:18 PM
Jokerman's Avatar
Engine: slowtacular L03 305
Transmission: slushem 700r4
Strange coil issues
OK i went down to the local oriely's (sp) and picked up basically the entire ignition system short of a new distributor, you know, coil, cap, rotor, wires, plugs. Anyway i went to put on the coil in my 91 RS 5.0 LO3 and when i pulled it out of the box it looked the same but when i went to pull the old one i realized that the brackets that were in the box with the new coil wouldn't work. Why? Because the coil in my car was monted into the intake manifold with 1/2 inch bolts. It all looks very factory so i am not thinking its a hack job, but what is going on? All of the parts stores try to give me the same coil setup. I have even asked them to look at 5.0 chevy trucks and they get the same thing. Is this an older engine that could have been swapped in? If so were exactly is the vin on the engine so i can match it up. Thanks.
Old Aug 12, 2002 | 03:26 PM
Jokerman's Avatar
TTT
Old Aug 12, 2002 | 03:30 PM
Odyssey's Avatar
It's simple really. You take the old coil off with the bracket attached. Then you drill out the rivets that hold the coild to the bracket. Then you put the new coil on the bracket and use the supplied bolts (usually the give u new bolts) to secure the new coil on the bracket!
Old Aug 12, 2002 | 03:38 PM
Jokerman's Avatar
Crap that means i have to drill out both coils. Oh well yet another project. Thanks.
Old Aug 12, 2002 | 03:44 PM
Odyssey's Avatar
Yeah... sometimes GM does some stupid crap like that and we have to live with it.
Cornholio7979
Sep 20, 2018 02:31 AM
Infested
May 22, 2018 11:56 PM
someone972
Aug 30, 2015 12:52 AM
red90IROCls1
Aug 25, 2015 06:56 AM
transamgta1Khp
Aug 17, 2015 12:18 PM
