Valve Seal replacement
Old Aug 12, 2002 | 03:21 PM
trd51398's Avatar
Hey Everyone,
i have an 88 iroc with the 5.7 350, when the car sites for a couple of hours and then I goto start it, it blows blue smoke for a few seconds, and I understand that its the valve seals. Does anyone have detailed instructions on replacing them? are they very difficullt to replace?
is there anything else I should replace while doing this?
ANyhelp would be much appreciated
Old Aug 12, 2002 | 05:30 PM
ede's Avatar
ede
try doing a search, you ought to be able to get enough hits to keep you busy for a while reading
Old Aug 12, 2002 | 05:39 PM
trd51398's Avatar
thats the answer I thoughtI would get,,, no wonder I never post here
Old Aug 12, 2002 | 05:48 PM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
so whats wrong with that answer ? How many times does a person need to type the same text. Do a search and then ask any unanswered questions. Doing the seals isnt too tough. Alot of guys here on the board have done it...your question is answered in the archives.
Old Aug 12, 2002 | 05:50 PM
trd51398's Avatar
all that had to been said was ,, yes it was done , look under the search,,, because I looked today on the search and couldn't find what I was looking for
Old Aug 12, 2002 | 05:51 PM
ede's Avatar
ede
it's a valad answer with more opinions and options that i could ever begin to put together for you. i thought i was helping you, no wonder i get tired of answering questions for people to inept or lazy to do a search.
Old Aug 12, 2002 | 06:38 PM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
Go read these how-to's
http://vettenet.org/vlvseals.html
http://www.dmcarclub.com/members/tec...lve_seals.html
When I went to replace my valve seals I noticed that I had a bunch of broken valve spring dampers (those coils inside the valve spring itself). I guess it was from over reving the motor for all those years ...that gave me a good reason to get new heads and new cam Luckily none of the broken peices got into the motor.
Instead of using compressed air I used nylon rope. I filled the cylinder as much as I could and then turned the motor over using the crank pulley until the piston came up and pinched the rope. I felt much safer doing this rather than air.
If you try to do it and aren't 100% sure on what you're doing ask here because you really don't want to screw something up and have to pull your heads off .....boy does that suck
Old Aug 12, 2002 | 07:02 PM
uidzer0_z28's Avatar
wow i would really like to do this. Those web sites made it seem so easy. I wish I knew someone who was more experienced with valvetrain components than me to help with the proceedure.
-Ben
Old Aug 13, 2002 | 06:38 AM
trd51398's Avatar
hey 88Iroc
thanks for the post,,,,, I was on late last night and found one of you threads about the springs. This is the first one I am doing and I wanted to get alof of information on it before I tackle to problem
I am actually thinking about replacing the cam now and put aluminum heads on the car maybe next year, but still need to fix the seals now. The engine is totally stock, by replacing those two things, will I notice a big difference? and can you recommend and good ones at a resonable price?
Thanks again for yoru post
gta90
Sep 15, 2015 04:00 PM
NBrehm
Aug 25, 2015 11:49 PM
86White_T/A305
Aug 17, 2015 12:16 AM
Leggman1
Aug 6, 2015 04:15 AM
