cold start problem please help!!!!
Old Aug 12, 2002 | 04:25 PM
paul russell's Avatar
Car: 86 trans am
Engine: 5.0 tpi gtauto ramair and notch
Transmission: 700 r4
i have a 86 t/a 5.0 H.O. this prob just started when the car sits overnight it will not start unless i hit the accelarator 1 time while cranking then its fine all day? any sugestions would help me out alot btw tune up was done 6oo miles ago fuelfilter included.mas was replaced and computor was cleared no codes at this time thanks
Old Aug 13, 2002 | 02:02 AM
rezinn's Avatar
How long does it take for fuel pressure to bleed off after the car is shut down? Try to clamp off the return line carefully(at the rubber section beside your washer fluid tank) and see if the pressure bleeds off as quickly. If so, I'd guess your injectors are leaking and causing the hard starting.
If you don't have access to a fuel pressure guage, you could just pull the fuel pump fuse before you shut the car down at night and let it run until it dies, then replace the fuse and see if you have trouble starting in the morning.
Old Aug 13, 2002 | 04:53 AM
Car: 86 trans am
thanks great idea will give it a try
92camaroJoe
Jul 29, 2023 07:57 PM
Wade787b
Sep 29, 2015 01:15 PM
92camaroJoe
Aug 13, 2015 06:07 AM
mustangman65_79
Aug 8, 2015 12:07 PM
drathaar907
Aug 6, 2015 04:20 PM
