Can someone tell me where to find NHRA regs to get a 12/11sec car track legal?
Old Aug 13, 2002 | 05:20 PM
ChrisFormula355's Avatar
Car: Junk
Engine: Junk with nitrous
Transmission: Junk with gears
I have a car (my grand prix) that will run low 11's on a 100 shot of nitrous, and mid 12's on the motor with slicks. What do I need to do to make it track legal? I'd like to finally run it at the track to get some concrete numbers. I'll be running slicks and the battery is in the trunk. So far, I know that I need a battery cutoff switch (which I already bought but haven't wired in) and I need all stainless steel or hard line fuel line. What else?? Do I need longer wheel studs if I'm running slicks? What about driveshaft loop? The grand prix has a "factory" style driveshaft loop already, anybody know if that'll fly with the track officials? Is there a website or something? Thanx
Old Aug 13, 2002 | 06:04 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I'm pretty sure 11s you need a roll cage.
Old Aug 13, 2002 | 06:28 PM
rezinn's Avatar
I know there are several websites that will tell you, just search for "nhra rules 12.99 13.99" and see what comes up. I know you need a driveshaft loop if you've got slicks, and obviously a helmet and seat belts are a must. You do need roll BARS below 11.99, cages below 10.99.
Old Aug 13, 2002 | 06:34 PM
Boxeat2469's Avatar
If you have a trunk mount battery it must be sealed from the drivers compartment. Just the backseat won't do, you'll have to put some kind of sheetmetal between the trunk and passenger area. Or, you can use a NHRA approved sealed battery box. The driveshaft loop must be NHRA approved, which means 2" wide by 1/4" thick and I believe within 6" of the trans side u-joint. Seatbelts are a must at any ET. Helmet if you're 13.99 or faster. Wheel studs must extend out of the lugs, no closed end nuts. Minimum four point roll bar for 11.99 and faster. Roll cage for 10.99 and faster.
Old Aug 13, 2002 | 07:06 PM
ede's Avatar
ede
check their web site, it'll tell you where to send acheck for a rule book. you'd be a fool to not have one and a bigger fool to believe what you're told on here without checking in your rule book. last one i bought was 12 dollars.
Old Aug 13, 2002 | 08:11 PM
iroc22's Avatar
Yeah my local auto parts stores carry the NHRA rulebooks, I've picked a few up from a couple years. Very good book to have.
specialized
Jun 18, 2022 09:26 AM
onefreakz
May 14, 2018 12:15 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
z28addict8490
Aug 7, 2015 08:48 PM
3rdgenparts
Aug 6, 2015 09:03 AM
