Engine Run-on
Old Aug 14, 2002 | 08:22 AM
Matty377's Avatar
Car: '86 Camaro
Engine: LG4
Engine Run-on
My 86 LG4 keeps running after removing the key.
If I let it warm up, the motor gets a little shaky, then I turn off the key, and the thing just keeps turning until i put it in 1st and force the engine to stop.
I know timing is a possibility, but I want to know if a high idle would be able to cause this because when this happens the car is warmed up and my car was idling high when the worst case of this run-on happened.
I just want to know what could be most likely causing this.
-Matt
Old Aug 14, 2002 | 08:34 AM
1986redbird's Avatar
sounds like you have timming issues and possibly a vacuum lead which would cause your high idle. sometimes if you adjust the idle stop screw in too far and hold the butterfly flaps open too far the engine will run on.
Old Aug 14, 2002 | 09:36 AM
Matty377's Avatar
Car: '86 Camaro
Engine: LG4
Where is that screw on the q-jet?
Is it accessable without taking apart the carb?
Thanks in advance
-Matt
Old Aug 14, 2002 | 10:43 AM
its on the driverside of the carb near the bottom of the carb, if you find the lever the throttle cable attaches to, look at the bottom of the lever and you will see the screw. it takes a trox bit to adjust it, i'm not sure what size though. you may have to remove the air cleaner housing from the carb to help you see it.
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
