Distribtor pick up coil
Old Aug 16, 2002 | 04:26 PM
FJK's Avatar
FJK
Still trying to find no power problem above idle on my 92 Camaro V6, 3.1L. Problem really comes in when the engine is hot, so I checked ohms across the pick up leads in the distributor. Spec is 500 - 1500 ohms. I'm reading .38 on the 20M scale, which is almost an open. The question is, does the distributor have to be removed to change the pick up coil, or can it be done in vehicle. Thanks, FJK
Old Aug 16, 2002 | 05:53 PM
rezinn's Avatar
I've got an aftermarket distributor that doesn't need to be removed, but I checked a reman one for our cars at autozone(not sure if it's the same for a v6), and you didn't need to remove the distributor from the car. However, I remember reading that you needed to remove it in a shop manual. I think it could go both ways. Just pull the cap off and take a look. If you can't get it off from the top it's time to pull it and dissassemble.
Old Aug 17, 2002 | 04:56 AM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
sorry
Old Aug 17, 2002 | 04:59 AM
Engine: 406
again
MM2Robinson
Oct 1, 2017 09:16 AM
timonator
Sep 17, 2015 06:57 PM
89-91fun
South West Region
Sep 12, 2015 03:06 PM
Jlanz55
Sep 6, 2015 03:05 PM
Jlanz55
Sep 6, 2015 02:35 PM
