what about this cam on a 305??
Old Aug 17, 2002 | 12:40 AM
dans82bird's Avatar
Car: 1988 Mustang GT
Engine: 302
do you think a Crane Cam 278H10 278 degrees, .467 lift would be too much on a 305 l69?
Old Aug 17, 2002 | 01:11 AM
Xenodrgn's Avatar
No.
It just won't idle, not steetable, and definatly not get a lick of MPG...
Mark A Shields is running a Comp Cams XE268 in his 305 with good results (from what he could tell...) talk with him more once his engine is back on the road and he'll tell you how he likes it...
I'd say the XE268 is as big as you'd want to go on a street 305...
Old Aug 17, 2002 | 01:33 AM
BumpaD82's Avatar
Car: 1982 Z28 & 1967 RS & 2002 Z28
Engine: 388 ci SB / 454 ci BB / LS1
Transmission: 4 speed / TH350 / T56
Axle/Gears: '91 "1LE" rear, posi w/ 3.23's
TOO BIG
too big, an XE268 is too large also in a 305 IMHO,
BUT some people like big cams that won't idle, or make any power
Old Aug 17, 2002 | 02:05 AM
JR305's Avatar
I think Mark A Shields is running the XE268 in a 350. The cam I have in my 305 has a good lope to it, that cam would give you a very choppy idle.
Old Aug 17, 2002 | 03:39 AM
TBI305Camaro's Avatar
Yeah Mark is running a 350 not a 305 anymore. Ive been looking for a cam for my 305 and may go the route JR went with the zz4 cam. You should have a very large cam selection since your 305 isnt a roller motor (correct?).
Old Aug 17, 2002 | 09:49 AM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
XE 256 for a streetable 305 automatic.
A few folks have run the XE 262 on a 305 but aren't unanimous in whether or not they like it. Requires 3.73 gears for sure and a loose torque converter. Or a stick.
The Crane PowerMax 260 and 266 are good choices, also. The PowerMax 272 is the Crane equivelent of the Comp XE 262, but is a newer grind with more torque and hp across the board--at least according to the ads
Jake_92RS
Jan 28, 2020 10:37 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
beastin91rs
Oct 9, 2015 07:38 AM
michealleger
Aug 26, 2015 03:29 PM
theurge
Aug 21, 2015 12:46 PM
