Top speed run failure...
Old Aug 17, 2002 | 01:35 AM
89WS-6's Avatar
OK, I have a 1989 Pontiac Firebird WS-6. 305 TBI, I tried to get it to go fst today. BTW 700R4 and 2.73's. Well anyway, I was at about 115 still in 3rd gear at like 4200-4300 RPMS. Well as yall might know, the 305 TBI's made NO top end horsepower, there perk was a decent amount of torque. So here I am like redlining (almost) in 3rd, and Im like, SHIFT SO YOU CAN GET INTO A DRIVE GEAR!!!! And it suddenly like shuts off, and coasts. I dont mean the engine shut off, but it dropped to like 2500 RPMS and started coasting. Well, what I am asking is, is this the govenor that I hit? And if so, WHICH WIRE DO I CUT!!! j/k cause I would really like to be able to go faster, just in case one day I had a... ummmm..... incident.
Old Aug 17, 2002 | 01:54 AM
JR305's Avatar
Look here .
Old Aug 17, 2002 | 02:41 AM
zroc's Avatar
Car: 87 IROC
Engine: LB9 for the moment
In my 89 T/A (5.0 tpi t5) I changed the rear end out to a 3.73... all the sudden when I shift into 5th and get back in it it shuts down (just like my 92 RS does) at around 115mph (the speedo is reading a lot higher)... it still wants to go up to that point... before I changed the rear out I could go past that point in 4th without incident... I know I need to re calibrate the speedo but this is an 89 tpi car... what the h*ll...
zroc
Old Aug 17, 2002 | 03:59 PM
f-crazy's Avatar
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
i dont remember were i saw it but it was on a gm site of some sort and it said unless your car l;eft the factory with zr rated tires your car has a speed limiter...those of u with the factory 245/50/zr16 do not have one
Old Aug 17, 2002 | 04:11 PM
88Bravo's Avatar
Car: 1988 Pontiac Firebird, flat black
Engine: Stock 305 LO3
Transmission: Five speed
All cars have one. The Z rated cars came with one of 254. But I was talking to a friend that has a Z28 4th gen, z rated and all, and he had one of 118. The best thing to do is get the PROM redone and have it bumped up. If you cut the wire, doesn't that senser doe something with the tranny shifting? The prom is still the best way, but a toggle is a good short term.
Old Aug 17, 2002 | 04:19 PM
f-crazy's Avatar
Engine: CARBED LT4
Transmission: MK6
yea but whos gonna hit 254?.....
i know there at 254 but why mention it if the car wont do over 145 and 165 for 4th gens
Old Aug 17, 2002 | 11:54 PM
Jon92TA's Avatar
Car: 92 Trans Am - Sold
I heard somewhere before that 254 was the max number that you could program in to 'remove' the limiter.
Old Aug 18, 2002 | 02:23 AM
89WS-6's Avatar
Originally posted by JR305
Look here .
:hail: you :hail: thank you, i will surelt look into that, surely.
1992 Trans Am
May 10, 2023 07:19 PM
Poncho92
Group Purchases
Aug 25, 2015 02:17 PM
InfinityShade
Aug 22, 2015 08:00 PM
kyleb24
Aug 15, 2015 08:24 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
