snapped bolt!
Old Aug 17, 2002 | 01:39 AM
holmes677's Avatar
snapped bolt!
I recently pulled the 305 engine from my camaro. while pulling the engine, we put a bolt in opposite ends diagonal from each other at the two farthest bolts holes in the heads and strung a chain between the two. As you can imagine, something had to go wrong. One of the bolts snapped off flush with the top of the head. I dilled down into it and ran a tap down in it, trying to be able to turn the bolt out, the tap broke and now i cant drill it out anymore b/c the tap is too hard a metal. I NEED HELP! Any idea would be greatly appreciated. I figured i could take it to a machine shop, but i dont want to spend the money if i could do it myself.
Old Aug 17, 2002 | 04:13 AM
93ND500's Avatar
I've done that before....breaking off a tap. When I did it, I used a Dremel tool with a diamond tip bit to grind the tap out. One question....why did you use a tap and not an ez-out?
Old Aug 17, 2002 | 05:52 AM
ede's Avatar
ede
weld a 1/2"nut on the stuband use a wrench to get it out
F-body driver
Mar 6, 2023 11:44 AM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
billybob6110
Sep 23, 2015 01:30 PM
Jlanz55
Sep 6, 2015 07:28 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
