front end shakes at 75mph
Old Aug 17, 2002 | 04:45 PM
pardonme2711's Avatar
while i am getting a new engine put in a figured why not fix everything that i possible can fix right now with this car! At about 75 mph's the front end of my car starts to shake bad, the dash jumps up and down really bad, it makes for a bumpy ride. Any input or suggestions as to the culprit would be greatly appreciated!
Old Aug 17, 2002 | 05:10 PM
nikh23's Avatar
Car: 88 IROC Convertible
Transmission: Raptor 700
hmm, try gettin the alignment checked, thast usually one cause of shaking at high speeds
Old Aug 17, 2002 | 05:35 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Bent wheel, separated tire, tire out of balance, worn steering parts
Old Aug 17, 2002 | 06:45 PM
SinthetikIroc's Avatar
Car: Corvette
Engine: 5.7
uneven air pressure between the 2 tires, crappy rotors, loose sway bar links, list goes on and on. i'd def go for the sway bar busshings etc kus thats real cheap like 10 bux and 25 or so mins and its done. id jus check it before it snaps like mine did then it really drives like ****.
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
Amillionoh7
May 24, 2020 08:01 AM
bellez77
Sep 5, 2015 08:39 PM
bamaboy0323
Sep 3, 2015 06:07 AM
