Whats the deal with the Converter lockup switch
Old Aug 18, 2002 | 08:38 PM
Larry Dunlap's Avatar
Car: '91 Formula
Transmission: TH350 built
Ok the tech board has a procedure for putting a switch on a jumper between a couple of terminas on the ALDL terminal that locks the converter in all gears except first. Yes, this is hard on the tranny, but If you only turn it on when racing you will probalbly be OK right? What do you all think? I go to the strip about once per month, will I be all right? Will it give me any advantage.?
Larry
Old Aug 18, 2002 | 10:53 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Try it and see.
I've been tempted to try it, but with 180K miles on the stock trans, I've been a little hesitant.
AJ
1992 Trans Am
May 10, 2023 07:19 PM
dyeager535
Aug 28, 2015 08:10 AM
overdriv
Aug 20, 2015 03:52 PM
Dialed_In
Aug 20, 2015 01:45 PM
86IROC112
Aug 17, 2015 02:00 PM
