Is one of these a return line?
Old Aug 19, 2002 | 12:00 AM
Dolph88sc350TPI's Avatar
Car: 88 Camaro SC, 86 T/A, 92 Eclipse
One of them is the return line right?
We are dropping in a carbed 305 and plan on keeping the electric fuel pump setup.
Does it need a 3-port FPR or can we run a plain jane FPR and do something with the return line???
I heard a 3-port is safer and easier on the pump.
Old Aug 19, 2002 | 12:58 AM
Morley's Avatar
Yes.
Old Aug 19, 2002 | 02:39 AM
What I really want to know is...., what needs to be done with the return line if a 2-Port FPR is used?
I shouldn't just block it off right.
Old Aug 19, 2002 | 09:15 AM
Vader's Avatar
If you retain the electric fuel pump you'll need to install a pressure regulator that can relieve the excess fuel volume back to the tank. The smaller of the two lines is generally the return line.
Old Aug 20, 2002 | 08:09 AM
bhaas's Avatar
I just use a mechanical pump that bolts to the side of my block and it's just hooked up to the return line for fuel. Works great.
Brad...
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
R13_Braz
Sep 18, 2015 05:00 PM
armybyrd
Carburetors
25
Sep 13, 2015 01:49 PM
TBRays98
Sep 6, 2015 05:05 PM
