Headlight fuse
Old Aug 19, 2002 | 12:48 PM
Makai's Avatar
Headlight fuse
Is there such a thing as a passenger headlight motor fuse?
Where is it located?
Door won't go up, but it will go down. Replacing the motor didn't help.
It's an 86 TA 305 4 barrel
Old Aug 19, 2002 | 06:11 PM
SMasterson's Avatar
Car: '89 GMC Pickup
Engine: 383 SBC Stealth Ram
Transmission: 700R4/VIG 3200
Re: Headlight fuse
If you have a problem with one headlight door that will raise, but then now lower again until you do it manually, there's a fuseable link on the frame rail by the drivers side wheel well opening. It looks like two little loops sticking out of the harness that runs to the front of the car.
If it won't go up then you need to check the single realy for that side. If the other one works then the master relay that's fused is good but that side is bad.
Hope this makes sense, almost doesn't when I read it back to myself. But, I did figure all this out about 10 years ago when I had Firdbird headlight problems.
I don't know of a single fuse for just one side.
Old Aug 19, 2002 | 06:35 PM
Makai's Avatar
Here's the link to my original post with all the details on the problems i'm having with this.
https://www.thirdgen.org/techbb2/sho...hreadid=126586
And your right, it really does sound confusing especially to me. You wouldn't have a pic of this location would you or anyone else reading this?
Thanx guys, Marie
3rd gen money
Oct 11, 2019 09:57 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
