I have a few questions
Old Aug 17, 2002 | 01:25 PM
White84B/dubz's Avatar
first off i was wondering if anybody could give me a few pointers on converting a b&m megashifter to use stock shifting cables, ive been doing some research and wanted to see what i get here, and second of all my car makes this funny clicking sound when i accelerate and i think it might be the u joints, so is there any way i can tell if it is the u joints? also i see alot of people have taken out their a/c, my a/c's compressor is broken so i was thinking about just takeing it out (i figured if i have lasted through summer this long i could last through anything) anyway i was wondering is it worth takeing out the a/c and how hard is it to do it. If anybody could give me some minor performance mods that dont require alot of money that would be nice, because i want my 305 to run a little better but iam in the process of gettting a 406 right now, so most of my money gose to that, all the help is greatly apreciated, Thanks
Old Aug 17, 2002 | 03:24 PM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
I think Morley did it..send him a pm or email....I think he may have a post on it.
Old Aug 17, 2002 | 09:04 PM
killer305's Avatar
i dont think u can use the stock shifter cable for the megashifter b&m sells them @ summit http://store.summitracing.com/partde...sp?part=10193. the ac isnt hard to take out, but if you want to do i right pick up a AC delete pully (search the boards for a place to find one) then just rip out all the ac s*th you see. and for some easy performace mods pick up a open element (tbi-card) or a a cold air intake from k&n.
Old Aug 17, 2002 | 09:35 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I used the stock cable. You have to cut the bracket off the stock shifter and drill a hole to bolt it to the new shifter.
Old Aug 18, 2002 | 12:20 AM
BAK12484's Avatar
any certain reason you wanna use the stock cable??
I put in B&M shifters in my camaro and firebird and used the supplied cable w/o any problems so far. Unless you are really against crawling around and getting a bit dirty, it's pretty simple...adjusting isn't bad either.
Old Aug 18, 2002 | 05:00 AM
Engine: 406
I also used the supplied cable..took a little while to adjust, but I haven't had any problems. Took about 6 hrs to install the shifter.
Old Aug 18, 2002 | 02:17 PM
well the reason i wanted to use the stock cable was that i heard the ones that b&m gave you arent all that great. thanks for the help
Old Aug 19, 2002 | 06:46 PM
BAK12484's Avatar
yeah there are people here that claim the shifter cable is absolute junk and will break....as of yet, i have haven't had it break on me yet. My brother also had a Megashifter in his old truck and that cable never broke either. I figure a brand new cable is less likely to break than a cable that has been in a 10+ year old car.
fasteddi
Sep 10, 2015 09:32 AM
masonta
Sep 1, 2015 06:40 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
