Need help w/ ignition prob
Old Aug 19, 2002 | 07:51 PM
MILT's Avatar
I am trying to figure out if I need a new ignition switch or if I have a short somewhere. Car is '91 LO3 w/ disabled VATS. Here's what I know so far:
1) An SES light is present upon turning key,
and it stays lit
2) Using the key will not crank engine
3) If I jump the purple starter will near
the starter the car starts fine
4) If I jump the wire at the NSS, nothing
happens
5) I tested the continuity of the purple
wire from the spot on the NSS to the
near the starter where I jumped it, and
it was less than 6 ohms.
Where should I look next? What should I test next?
Any help would be greatly appreciated as I have no idea what I'm doing.
MILT
Old Aug 19, 2002 | 08:25 PM
jfox55's Avatar
Have you checked the neutral safety switch??? That will cause the car not to crank at all, but all your normal lights to come on.
Old Aug 20, 2002 | 05:38 PM
MILT's Avatar
How do I go about checking the NSS?
Old Aug 20, 2002 | 08:08 PM
jfox55's Avatar
When the one on my cherokee started to go bad, I could wiggle it and get the car to start. The plug was just starting to go bad. If it is not just the plug, I really dont know how to test the switch. Some places I believe can test these like maybe Autozone or somethin. Maybe somone else on here could tell you how to test it. I am pretty sure you could probably use a voltameter or somethin.
Old Aug 21, 2002 | 01:03 AM
trans_am_racing's Avatar
Car: 2000 firehawk
Engine: ls1
Transmission: 6 speed
Axle/Gears: 3.42 auburn
just unhook the NSS from the switch on the steering column
Old Aug 21, 2002 | 05:45 PM
MILT's Avatar
Okay, I'm kinda retarded, so could you please elaborate on the "just disconnect the switch from column..."
Thanks,
MILT
Old Aug 21, 2002 | 10:14 PM
Car: 2000 firehawk
Engine: ls1
ok if you drop your plastic panel under your steering column, you can acess the column bolts, (13 MM ) take those 2 bolts off wnd your steering column will come down, if you look on the left side of the column you will notice a cable comming into it from the brake pedal area, use a small screwdriver to pop the plastic hook and the cable will slide right out then if your car does the same then its not the problem, it could be a slide in your ingnition mod itself, try that and see where it gets you....
db057
Jan 10, 2020 08:55 PM
RedLeader289
May 28, 2019 01:47 PM
Gunner242
Dec 25, 2015 04:49 PM
94ElBanditoDeCa
Aftermarket Product Review
Sep 23, 2015 09:05 PM
RedLeader289
Sep 23, 2015 06:50 AM
