Should CAT Glow on Inside
Old Aug 19, 2002 | 08:29 PM
FJK's Avatar
FJK
Still trying to track down no power off idle on 92 Camaro V6. I have the exhaust pipe removed from the outlet of the CAT & noticed the honeycomb iside the CAT is glowing red at idle. Is this normal? The exterior of the cat is not glowing red. I really hate to cut off the cat just to see if it's restriction is causing a problem. Has anyone modifed an old O2 sensor to make it into a pressure tap? I've heard max exhaust restriction is 3 psi @ 3000 rpm. Anyone else heard this? Help!
Old Aug 19, 2002 | 09:13 PM
slayer2000's Avatar
Car: 1990 GTA
Transmission: manual/t56
I believe that it should glow inside as long as the outside doesn't. The catalyst inside needs to reach a certain temp in order to work properly, so unless the outside starts to glow I'd say you're fine.
Old Aug 19, 2002 | 10:53 PM
lukerene's Avatar
Car: 1982 t top,,z/28,
Engine: 409ci vortec
Transmission: all steel t700r4,1300 stall yahooooooooooo
yes it is a mini incinerator,,,a mini,,,furnace for the ,,,deadly chemicals ,,,this junk fuel creates,,,,carconogenic,,,,dioxins,,,, dont worry about my spelling i know about this fuel,,,unleaded is deadly poison,,,,,,dont play with it,,,or wash parts in it,,,,,the cat will glow,,,,yes,,
LT1Formula
Oct 8, 2015 08:34 PM
jaridjohn
Oct 5, 2015 07:01 AM
racereese
Oct 3, 2015 03:46 PM
