towing my car
Old Aug 20, 2002 | 03:27 PM
microtek_10's Avatar
Car: 92 Z28
Engine: 355 tpi
towing my car
I have to pull my 92 z28 out to the shop tonight after work. What can i hook the tow rope too? i think if i went under the front the rope would come up and bend the ground effect. Thinkin maybe the strut tower brace or would that just rip the bolts outs. Need help ASAP. THANKS
Old Aug 20, 2002 | 03:31 PM
83 MidniteZ's Avatar
I would use a tow truck... (flatbed of course)
Old Aug 20, 2002 | 04:03 PM
PonyKiller87's Avatar
Car: 87 Iroc Z28
Engine: 355 TPI
dont use that brace that goes down from the hood latch to the air damn. Because if the guy sitting in the car hits the brakes and the strap tightens up it will sinch and crush the bracket and then rip it off the radiator, and break alot of plastic stuff undernieth the bumper.
The only decent way that I have seen it done was by making a tow bracket. I seen it at a shop once that a guy used to tow his car around at the track. It was a 2" wide by 1" tall steel c channel about 3 feet long. It bolted onto the frame where it goes under the motor (I guess he had the holes taped or something), on the other end he had a hole in the channel where a tow hook could go in. The guy that had it said that it worked very well. I havent had to tow my car recently so I never made one.
Old Aug 20, 2002 | 06:31 PM
RODS92Z's Avatar
I pulled that car with a 2" inch strap tow rope. Hooked it on the passenger side frame rail, theres a hole there to hook it and just hook it as low as possible on the pickup, like around the axle. It wont hurt anything just have the guy in the car keep the strap tight.
Old Aug 21, 2002 | 02:44 PM
firechicken_3's Avatar
Car: 1984 Firebird
Engine: 350 Terminator EFI
Axle/Gears: 4.10
the sway bar works to......
if your using a rope you could use the front crossmember, you should be able to get a rope through between it and the motor
BlueIroc-Z
Jun 9, 2019 03:22 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
