What would cause a car to die when it gets hot?
Old Aug 21, 2002 | 02:36 PM
khellendros's Avatar
What are any/all the reasons a car will die when it gets hot (210-220 degree). Thanks
Old Aug 21, 2002 | 05:06 PM
Ratstix's Avatar
210-220 should be fine. thats not hot at all.
if it died between 250-260. then i'd be worried about heat.
Old Aug 22, 2002 | 05:08 PM
cdogc350's Avatar
Choke not fully opening upon warm up
Old Aug 22, 2002 | 07:25 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
make sure there is a good amount of fresh dielectric grease under the ign module and also that carb fuel is not boiling in the bowl or lines, and that the pickup coil is not messing up on you
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Wade787b
Sep 29, 2015 01:15 PM
killer777
Aug 8, 2015 02:47 PM
