idle question
Old Aug 24, 2002 | 11:31 PM
91firebirdfosho's Avatar
Car: 1991 firebird formula
Engine: 383
Transmission: th350
Axle/Gears: 3:73 posi
idle question
What would cause my car to idle for example 700 rpms and as u walk away from your car it jumps up to 1200 for no reason
what part makes it do that
thanx nick
Old Aug 25, 2002 | 01:24 AM
Low C1500's Avatar
Car: 89 Shortbox
Engine: 350 Vortec
Theres lots of variables that effect Idle, but ultimatly its the IAC (idle air controller) that has mechanical control, as it allows air to pass by the butterflys.
Old Aug 25, 2002 | 10:38 AM
Vader's Avatar
It is possible that the ECM is going from closed loop to open loop, and back. This can happen on an idling engine if the exhuast temperature is not high enough to maintain an adequate O² sensor signal. That can cause variation in idle, as well as any unknown variables in the HyperScrap PROM you have installed.
As C1500 said, the IAC is the ultimate controller of idle speed, so it and the air passages must be kept clean to have accurate idle control.
MustangBeater20
Oct 29, 2022 09:20 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
