please HELP!! car won't stay running
Old Aug 25, 2002 | 03:18 PM
mrbboy's Avatar
I just finished replacing my intake gaskets. The car starts fine but when I put it in gear (reverse or drive), the car dies. I have no problem starting the car up again? Does anyone know what my problem could be? I already checked the vacuum lines and all electrical connections. What else could be causing this?
Rene
91 305 TBI auto
Old Aug 25, 2002 | 03:34 PM
ede's Avatar
ede
no codes? timing right? no vacuum leaks? iac or tps set correct?
Old Aug 25, 2002 | 03:35 PM
si_camaro's Avatar
Car: 85 Z28
Engine: LG4 modified
As a stab in the dark, maybe the idle speed is too low? I know you've probably thought of that, but you never know.
Old Aug 25, 2002 | 04:32 PM
mrbboy's Avatar
How do I check for codes? Also, I didn't remove the TBI from the intake when I replaced the gaskets so I don't think anything got changed as far as idle speed goes.
Old Aug 25, 2002 | 05:11 PM
ede's Avatar
ede
jump the a and b terminals of the aldl. if you don't have a ses light on you don't have codes. you sure all the vacuum lines are on?
Old Aug 25, 2002 | 05:14 PM
mrbboy's Avatar
Yes, I checked all the vacuum lines again. They are all on there tight. I am going to look at the timing again and see also see if my distributor is still lined up (from the marks I made before removing it). I'll also check the timing again. There is also no SES light.
Rene
91 305 TBI auto
RazorN8
Jan 7, 2022 11:44 AM
justin57
Aug 20, 2015 07:05 PM
Kaweh
Aug 9, 2015 02:54 PM
Sherpajames
Aug 7, 2015 06:56 PM
