Fuel pump question
Old Aug 27, 2002 | 05:47 PM
88355's Avatar
Car: 88 I-ROC
Engine: 355 TPI
Transmission: BW T5
Fuel pump question
hello ..i just recently installed a newAccell HEI(divorced type coil) coil and new Accel modual in my 88 TPI 350...no biggie...r&r'd both no problem..easy going.went to start the car..Vroom....went for a test drive and she lays right down on medium to hard acceleration...MAN!..WTF i said to myself...no popping or back fireing..car just won't go..kinda like a clooged cat..never had this problem before..now I have a car that turns over..but will not start..spark is there...timeing is correct..and fireing order is good also (checked 3 times) The car turns over but engine won't fire up.I have noticed the pump no longer hums when the key is turned on..the relay does click twice..once for on.."hmmmm"..then click again for off about a 3-5 sec between clicks (NO humm currently..just clicks from the relay) I also have no psi on my guage for gas.PUMP!!!!...you will probably say..but is there any other device that tells the pump to "prime" or turn on???? before i roll my sleeves up and start swearing at the task that lies ahead of me. i wonder if the pump died from the coil or modual.Hope I explained enough..will explain more if requested
thanks for your time people
Brent
Old Aug 28, 2002 | 12:03 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
You seem to have it covered...if the FP relay is clicking,, then check for 12v at the pump before yanking the fuel pump.
If no 12 at the pump, then check the output of the relay, if no 12v out of the relay, check the input and follow the source,
Good luck
Old Aug 28, 2002 | 12:07 PM
TBI305Camaro's Avatar
I doubt the module or distributer had anything to do with it. Any time I add something to my car something else breaks. I think the car just likes to **** me off.
Old Aug 28, 2002 | 12:10 PM
88355's Avatar
Car: 88 I-ROC
Engine: 355 TPI
Transmission: BW T5
thanks Mike for getting back to me.Will do what you suggested...I'm just baffled on the timeing of this whole event..kinda like magic i guess...new coil and modual..fuel pump dies...hmmmm...oh well..she (the pump was humming kinda strange couple weeks ago ..hhhmmmHHMMMMMhhmmmmm....sounded kinda sick to me..but i guess it finally quit..lol
thanks again Mike..will let you know on the outcome
Brent
Old Aug 28, 2002 | 12:12 PM
88355's Avatar
Car: 88 I-ROC
Engine: 355 TPI
Transmission: BW T5
LOL..thanks also TBI305 for your input also..yeah..i guess my car is like a woman..never can keep her satisfied :>)
thanks again
Brent
Old Aug 28, 2002 | 12:59 PM
If it is indeed the fuel pump are you gonna do the install the right way or are you gonna cut a hole in the floor? I knew nothing at all about my car at the time my pump went out and it took me a good day and a half to do. Id definetly get a better fuel pump while your in there instead of a stock replacement.
Old Aug 28, 2002 | 01:08 PM
88355's Avatar
Car: 88 I-ROC
Engine: 355 TPI
Transmission: BW T5
i would love to cut a hole in the floor if i had exact measurements..man..i'm gonna hate doing it the regular way.
i was going with a GM pump and sender..this one lasted 120,000....good thing the motor i built is new
Old Aug 28, 2002 | 02:21 PM
GTA-SPD's Avatar
Car: 94 Corvette
Engine: LT-1
Transmission: Freakin Automatic---For Now
88355 - As someone who has done this job a couple of times (pump in my 87 and a tank replacement in my first 82 not to mention the one in my 94 Grand Am, and oh yeah the one in my 90 Chevy truck) don't get anything cheaper than a dealer pump. Those AutoZone, Checker, etc. pieces of sh*t cant handle running out of gas even once. That includes the occasional fuel slosh induced dry sump condition caused by a hard corner with low fuel. By the way, lowering my car made it's fuel pump crap out on me, or maybe it was the alignment... Damn cars. At least yours waited until you did something to the engine or electrical system before it jacked you. LOL BTW it only took me around 4 hours to do mine this last time, of course I'd just filled up with gas the day before. And just a little tip, even though it doesn't look like it, you do need to drop the rear diff down to get that bastard out. I tried and tried to do it with the diff bolted in, and I just couldn't get it out. Just keep a few beers on hand and when you start getting pissed off, drink one.
Old Aug 28, 2002 | 04:26 PM
88355's Avatar
Car: 88 I-ROC
Engine: 355 TPI
Transmission: BW T5
yeah..i hear ya on what lies ahead for me...My tank also is full..LMAO.Filled her 2 weeks ago..of course not expecting this to happen. I will be getting GM pump and sender,and strainer..always been a "Dealer" type person when it comes to parts like the pump and such.
I still can't believe the uncanny timeing this has happened.
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
