whats better? LG4 heads or stock 1978 350 heads
Old Aug 29, 2002 | 05:49 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
this guy at work will sell me a set of LG4 305 heads in excellent condition for $100
the first advantage i see of the LG4 heads is the 58 cc combustion chamber
second advantage is that these heads are in great condition
the valves are 1.84/1.5
what is the combustion chamber size on the 350 heads?
valve size?
i am building a nice mild 350 for my daily driver (and i'm on a major budget) so AFR's, Brodix, etc are totally out of the question
i plan on using a computer compatible cam and Speed Density TPI
what comp-compatible cam should i choose if i go with the LG4 heads?
do they make that cam in a retro-roller version........if so i would like that the best
thanx for you help
Old Aug 29, 2002 | 08:46 PM
Xenodrgn's Avatar
*bump*
Wanna swap that 3.1's 5-speed into my car Glenn?
And whatever happend to putting the t-5 behind the 305? e havn't talked in a while, it seems your plans have changed quite a bit...
BTW, congrats on the 350/350 score!
Old Aug 29, 2002 | 09:09 PM
iroc22's Avatar
I'd use the 416 heads probably over the 350 ones, unless they're L82 heads. What's the casting #?
Old Aug 29, 2002 | 09:20 PM
Originally posted by Xenodrgn
*bump*
well, xeno, you can have the motor for free
just be warned that it has nearly 200,000 miles on it
ehhh, i need to keep the T5 because i blew one up pretty bad
th TH350 is going behind the 305 and the other T5 is going behind the 350
weird combos, but hey, i gotta be unique
if you want the 3.1, i'd suggest rebuilding it first.........then i can put it in for ya
it wont be out for about 3 monthes though
as for the heads, i'm 99.99% sure the L82's only came on vettes and not trucks.......so it looks like the LG4 heads are a good deal.......i'll seal that deal in a few weeks
Old Aug 29, 2002 | 09:47 PM
HurtHorseZ28's Avatar
How "major" of a budget are you looking at?
Old Aug 29, 2002 | 10:28 PM
Xenodrgn's Avatar
'Ehh, I'm not too interested in the 3.1... I'm looking at some time next summer to swap in an 8.
As a matter of fact.. if it's still there next spring, It might just be a 400 with a 4 speed out of a 79 TA.
Old Aug 29, 2002 | 10:33 PM
Xenodrgn's Avatar
Are you going to be keeping both of these cars on the road? What drivetrains are going in what car? I'll take the one with the 305/th350...
Old Aug 29, 2002 | 10:45 PM
jimmy_mac's Avatar
Hey, while on the subject do any of you guys happen to know the volume of the 416 head's intake runners.
Old Aug 29, 2002 | 11:26 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
The stock port volume of the 416 heads is 167cc's
Old Aug 30, 2002 | 04:32 AM
well, lets not even consider a budget into the equation, lets just say, gave 2 choices of whats better, and i am going to be using whats best
Old Aug 30, 2002 | 04:37 AM
yeah dude, if you want performance, an 8 is the only way to get it, too bad i had to realize that the hard way
a pontiac 400? that'd be interesting, but i'm sure you can probably find a good deal like i did........i scored the running 350 and TH350 for $300.............the guy i bought them from said they both run great.............i just hope he's right and the piston rings arent shot...........the valve seals, i dont care, cuz i'm gonna get the LG4 heads.........
Old Aug 30, 2002 | 01:08 PM
iroc22's Avatar
yeah they didn't. I didn't see any mention of what 350 the heads were comin from in your post so that's why I asked.
Old Aug 31, 2002 | 04:51 AM
hey, no problem man
theshackle
Mar 5, 2017 06:37 PM
gta90
Sep 15, 2015 04:00 PM
camaro71633
Sep 1, 2015 10:24 AM
NinjaNife
Aug 23, 2015 11:49 AM
NWAsonoma
Aug 18, 2015 05:45 PM
