Power Chip
Old Aug 31, 2002 | 12:08 AM
MaroonBerlinetta's Avatar
Car: 1984 Pontiac Firebird
Engine: 307ci V-8
Power Chip
How many horsepower will a Hypertech Performance chip produce on my 1984 Firebird with a 5.0L 305 4 barrel carb
Old Aug 31, 2002 | 08:01 AM
kevinc's Avatar
Car: 1982 Z28
Not much, maybe ~10hp if your stock software was way out of whack.
Most aftermarket chips that have been disassembled show only a few degrees of timing and a wee bit of fuel added, fan temps dropped a few degrees, and that's pretty much it.
With your engine, the big areas for improvement are the heads, cam, and exhaust.
Old Aug 31, 2002 | 10:52 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
I agree with Kevin. In fact, for compu-carb engines of the mid-eighties, the computer did very little. An eprom is likely to make no difference whatsoever.
I would go to the "Carb Board" and discuss "other alternatives" to tuning, besides the eprom. You have the last of the cars where you can accomplish 95% of your tuning through mechanical methods AND it's effective.
It's more with the EFI cars that the "tuning" is more effectively done inside the eprom rather than by "alternative methods". And, for the most part, the "alternative methods" do more than an "off-the-shelf" eprom. You need either a custom eprom or (better yet), burn you own to get the maximum benefit.
Old Aug 31, 2002 | 04:57 PM
TPIterror's Avatar
Car: Formula
Transmission: M5
I has an ADS stage 1 chip in my 85 LG4 auto TA and noticed a slight increase and power and a higher shift point. Not bad for 89 bucks, but don't expect a substantial gain.
deracer
Apr 11, 2016 12:04 AM
bamaboy0323
Sep 3, 2015 06:07 AM
NBrehm
Aug 25, 2015 11:49 PM
sailtexas186548
Aug 24, 2015 10:11 PM
NWAsonoma
Aug 18, 2015 05:45 PM
