MAF Code Please Help
Old Aug 31, 2002 | 12:55 AM
JOHN/88IROCZ's Avatar
I have an 88 TPI 350 Iroc Z I have been getting a code 34 for months and months I took it to my mechanic when it first started and the scan tool he used said my computer and prom were bad cause it couldn't communicate with the computer so I replaced them . Then I replaced the MAF, the relay, the plug for the relay,and the plug for the MAF. I still get the code even after I reset the computer. I did pass the Texas treadmill emissions test today even though I had to go down to the muffler shop and replace my 2 yr old high flow cat. with a new one to get it to pass. Could a dirty cat throw a code 34, I have not tried to reset the computer since I got the cat replaced.
What I Replaced
computer
prom
MAF
relay
plug for relay
plug for MAF
O2 sensor
replaced and adjusted TPS
cat.
Old Aug 31, 2002 | 07:47 AM
Guest
Guest
Posts: n/a
The cat isnt going to have anything to do with the MAF. The 34 in your car is probably a vacuum leak of some sort. Check the vacuum lines and make sure the connection from the MAF to the TB has no holes or leaks.
Old Aug 31, 2002 | 10:37 AM
Cant you spray WD40 or Ether around the engine compartment to help find the leak? I cant remember what I used to use and this code 34 is driving me crazy.:lala:
Old Sep 2, 2002 | 12:10 PM
Marin's Avatar
Check vacuum, TPS and your O2 sensor...
Old Sep 2, 2002 | 12:11 PM
Marin's Avatar
Oh, yeah, maybe the IAC is stuck open (do TPIs have IAC?)... try posting this on the TPI board, they'll know what it is..
Old Sep 2, 2002 | 02:06 PM
Replaced O2 about a month ago and got the TPS adjusted. Thanks for the advise anymore that might help? John
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
Mark_ZZ3
May 24, 2018 01:02 PM
dusterbd
Sep 29, 2015 08:40 AM
indygene
Sep 26, 2015 11:21 AM
