quick quick quick wiring help
Old Sep 2, 2002 | 01:51 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
where does the thick black wire go from the positive battery post to the where??? its black and its only a couple feet long and it has a connection on the end where you bolt it down to something(looks kinda like a ground)
thanks,
brady
1992 camaro rs lo3
Old Sep 2, 2002 | 02:08 PM
ede's Avatar
ede
forget the color stuff in case someone mixed them. the - side of the battery is a ground and is usually bolted to the chassis ,but the engine would work. the + side goes to the starter
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
There's 2 battery cables. One (usually red) goes from the positive terminal of the battery to the big post on the starter. That one is fairly long, more like about 3 to 4 feet.
The short one is about 18 or 20 inches long and goes from the negative battery post to anywhere on the engine block, or something bolted solidly to the block.
Old Sep 2, 2002 | 03:51 PM
much appreciated guys. thanks.
brady
..........the swap continues.............
Jorlain
Aug 24, 2022 05:11 PM
Infested
May 22, 2018 11:56 PM
thefirebirdm@n
Aug 25, 2015 05:21 PM
