vacum at idle
Old Aug 31, 2002 | 01:04 PM
fastredtruck's Avatar
Car: 88 gmc 1500
Engine: 496
vacum at idle
whats up
just got my engine running a few weeks ago and it runs pretty good it deos run rich most of the time though. i have a 355 with a xe 268 cam and vortech heads with the z28 springs, an rpm airgap manifold and a 670 holley street avenger its got 9:1 compreesion. I was just wondering what you think the vacum should be at idle right now its about 12-13 is this good or bad as for it running rich should i jet it down or turn the pressure on the regulator down its set at 7 psi and the level in the bowls is correct.
thanks
Old Aug 31, 2002 | 01:09 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
That's a little low, i would expect to see about 15-16.
7 psi is more than you need; 5 is usually plenty, and with a good-flowing system, 3 will do.
with that low vacuum th epower valve is probably opening alot of the time at idle. that will make it run shamefully rich.
junior419
Apr 7, 2025 11:35 AM
Grant2k
Apr 4, 2016 08:21 AM
86IROC112
Nov 27, 2015 09:54 AM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
