Easy IGN switch question
Old Aug 31, 2002 | 01:16 PM
MILT's Avatar
Hello. I need to replace my ignition switch--the thing at the base of the steering column. I am trying to get a replacement @ carparts.com, but am not sure which one I need.
Here are the choices:
Ignition & Start Switch, 4-Speed AT; (Incl. Formula)
•AC DELCO D1408B $26.05
Steering Column Lock & Ignition Switch Cylinder, 4-Speed AT; (Incl. Formula)
•AC DELCO D1456C $36.41
Ignition Switch - w/Tilt Wheel, w/A.T. (Incl. Formula)
•BORG WARNER CS142 $29.91
IGNITION SWITCH-SWITCH W/ TILT
•STANDARD US-105 $12.27
•STANDARD US-131 $22.76
Grrr...I don't want to order the wrong thing. Obviously I have an A4 trans and tilt. The auto parts store quoted a part for $70!!!
Thanks for the help...
MILT
P.S. Why would my ignition switch start on fire?
Old Sep 1, 2002 | 12:20 AM
formula90's Avatar
Car: 1990 Formula
Engine: 5.7 liter
it would be the 3rd 4th or 5th option. depends how long you want it to last is how much money you want to spend.... I would go with the borg warner... if that is your choices...
MustangBeater20
Oct 29, 2022 09:20 PM
Dkelz313
Apr 7, 2016 10:38 PM
fasteddi
Sep 2, 2015 10:29 AM
redmaroz
Aug 16, 2015 11:40 PM
Fronzizzle
Aug 9, 2015 01:15 PM
