Ignition coil
Old Aug 31, 2002 | 08:02 PM
CHCKLS's Avatar
Car: 89 Iroc Z Cnvertible
Engine: 409 SR
Transmission: 6 speed
Ignition coil
Heres the deal. I checked to see if I was getting a spark at the plug. I wasnt. So I checked to see if the coil was giving a spark. It isnt. So then I was told to check the ignition module and pick up coil. THats all well and good. I can check those tomorrow during daylight But I dont think I am understanding something here. The ignition module doesnt supply power to the coil does it?.....Would the coil be giving a spark even if the module or pickup coil was bad?....
Old Aug 31, 2002 | 09:33 PM
NY_Rebel's Avatar
The "pick up" is what tells the module to "fire" the coil. The module doesn't supply the voltage to the coil, it completes the circuit and controls what the spark does (esc).
It's rare for a coil or "pick up" to go bad....more common for a module. I'm not saying they (coils & pick ups) don't go bad...it's just not as common.
You can take the module off and take to the parts store and they should be able to test it for you...or you can buy a sensor tester that will test o2 sensors, tps, hall effect switches,magnetic inductor switches, and most modules for a decent price (at least it was a decent price when i bought mine several years ago).
Good luck...
Old Aug 31, 2002 | 11:03 PM
CHCKLS's Avatar
Engine: 409 SR
Yeah I got it. Just wasnt thinking it through. Thanks for the responce.
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
Gunner242
Dec 25, 2015 04:49 PM
school boy
Oct 22, 2015 11:47 AM
92rsvortec350
19
Oct 9, 2015 09:39 AM
