anybody install the Accel 300+?
Old Sep 1, 2002 | 08:07 AM
TPIterror's Avatar
Car: Formula
Transmission: M5
I just ordered the Accel 300+ ignition. I have a remote coil. The guy at Summit said I can remove the ignition module in the distributor because the Accel system bypassses it. But in the directions it has directions for leaving it in and taking it out.
Can i take it out? Any ideas?
Old Sep 1, 2002 | 01:01 PM
TPIterror's Avatar
Car: Formula
Transmission: M5
nobody has this ignition?
I need help!
Old Sep 1, 2002 | 03:26 PM
TPIterror's Avatar
Car: Formula
Transmission: M5
oy!
Old Sep 1, 2002 | 09:10 PM
TPIterror's Avatar
Car: Formula
Transmission: M5
am I being annoying yet? Nice post count, eh?
Old Sep 2, 2002 | 03:19 AM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
I have the 300+ ignition. You do not bypass the module. You unplug one of the factory connectors from the module and plug the new connector from the box harness in.
Here's the install diagram.........."Right click, Save Target As"
http://www.mrgasket.com/accelpdf/GMsmallcap.pdf
Old Sep 2, 2002 | 05:22 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
My brother has that ignition on his car and he doesn't have a module in his distributor. Actually, he doesn't have a distributor, per se, he's got an LT1.
Is the accel just as good as an MSD 6A?
Old Sep 2, 2002 | 05:44 AM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
I'm sure each box has it's admirers. I prefer the Accel box because it's small, has a built in rev limiter, and was a very easy install.
Old Sep 2, 2002 | 07:44 AM
TPIterror's Avatar
Car: Formula
Transmission: M5
So technically, you still need the module to be in good working order then, right? That kind of pisses me off, because I was going to order a new one, and the guy at Summit said it wasnt necessary, because the 300+ system bypasses it. So I guess now I better get a new one.
Old Sep 3, 2002 | 04:24 PM
TPIterror's Avatar
Car: Formula
Transmission: M5
Just spoke to Accel tech. They said I can leave it in or take it out...the 300+ bypasses it. Thats good cause I think mines shot.
Old Sep 3, 2002 | 04:38 PM
fattie92's Avatar
does the MSD 6A do this as well?
Old Sep 3, 2002 | 04:40 PM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
Errrrrr, you go ahead and remove that module. Keep it handy though. You're gonna need it to make your car start and run
Old Sep 3, 2002 | 05:11 PM
Zepher's Avatar
Doesn't the module tell the ECM to fire the injectors?
Old Sep 3, 2002 | 09:47 PM
TPIterror's Avatar
Car: Formula
Transmission: M5
Here's what I'm guessing based on what I've been told by Accel and from talking to you guys:
The module can be taken out on carb cars, but must remain intact on FI cars. In either case though, the Accel ignition setup overides it. Thats why I'm assuming there's two different wiring diagrams in the directions; one with it removed and one with it in.
Sound about right?
Old Sep 3, 2002 | 09:50 PM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
Well, you've got 2 weatherpacks on the back of the module. The new Accel harnees for the box only replaces 1 of them. I'm pretty sure you're gonna need the module.
Old Sep 4, 2002 | 01:00 AM
AdmiralNahohkta's Avatar
Car: GTO
Engine: GM 350HO, 4.6 Overhead cam, 413 Wed
I second you. Accel must have changed their directions to be more confusing lately because I don't remember anything about taking out/bypassing the module. Accel's wiring harnes simply plugs in where the stock harness used to be. Note: keep the stock harnes handy, my Accel crapped out after a year and I was able to quickly convert back the the stock ignition. Also, Accel was very good about replacing my box, ie: no hassles.
Built in rev limiters rule!
Infested
May 22, 2018 11:56 PM
tazs2000
Jul 15, 2017 08:44 AM
evilstuie
Feb 28, 2016 03:33 PM
355tpipickup
Alternative Port EFI Intakes
Aug 26, 2015 04:08 PM
marcusaw
Aug 10, 2015 08:13 AM
