How do i elongate manifold bolt holes?
Old Sep 3, 2002 | 08:31 PM
FormulaGod's Avatar
Yeah i got the StealthRam and want to elongate my holes in the two centers to fit my late model Trick FLows. How do i do it?:hail:
Old Sep 4, 2002 | 12:41 AM
flyway190's Avatar
I used a dremel and a multipurpose bit (you might want a few extras, they don't cost much). There's not much to it, just take off a little at a time on one hole until you can put a bolt through it into the head without resistance. Once you get one right, just use it as a model for the other three. The heads of the bolts won't be perfectly lined up with the top of the manifold, but it should still hold just fine. If you're really worried about that, I suppose you could use a washer and some pipe with one end cut at an angle.
evilstuie
Jan 9, 2020 08:29 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
