What type and size valve seals??
Old Sep 7, 2002 | 01:00 PM
BAK12484's Avatar
Im looking to replace the valve seals on my 'bird, but am unsure which ones to buy. I've found these two at Jegs, Comp Cams and Crane.... anyone better than the other? And which size do I need? Thanks.
http://www.jegs.com/cgi-bin/ncommerc...86&prmenbr=361
http://www.jegs.com/cgi-bin/ncommerc...88&prmenbr=361
Old Sep 7, 2002 | 04:43 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
All of those require machining the guide, as the text in the links says. If your heads haven't been machined, they won't work.
Get some Fel Pro ones; they are made to fit your stock guides.
Old Sep 7, 2002 | 06:53 PM
ede's Avatar
ede
yep use the fel pro positive seal and the o ring seal both.
Old Sep 8, 2002 | 01:14 AM
BAK12484's Avatar
thanks...
not remember if it was on this board, or whom i heard it from, but they said those would work even if your heads weren't machined...ah well, you guys know more so i'll stick to your word
toronto formula
Nov 10, 2015 06:17 AM
1Aauto
Sponsored Vendors
Aug 26, 2015 02:14 PM
1Aauto
Sponsored Vendors
Aug 24, 2015 03:40 PM
g.l.mos
Aug 22, 2015 12:02 AM
knight72
Aug 10, 2015 09:32 PM
