Think I can make 425 NA??
Old Sep 8, 2002 | 10:02 PM
FstBrd6point3's Avatar
I have a 383 that I am going to be putting an LT1 intake on along with the LT4 hot cam, 1.6 roller rockers and ported Iron swirl typle L98 heads that are being cut for 2.02, 1.6 valves.... I would like to see 425 horsepower with no power adders and then go for a 125 shot in the spring once I have a suspension and transmission that can transfer that much power. does it sound do-able?
Old Sep 8, 2002 | 10:06 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Hmm, I'm no expert, but, I think you'll need higher compression than the stock L98s give, what type of pistons are you getting?
Old Sep 8, 2002 | 10:20 PM
I already have the motor together and in the car... I am running 9.7:1 with the 64cc heads
Old Sep 8, 2002 | 11:43 PM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
Check out the fairly recent issues of Hot Rod and Chevy Hi Performance. They have both done 383 buildups and made more than 450 hp naturally aspirated
Old Sep 9, 2002 | 11:59 AM
Vader's Avatar
I have a 355 that makes 423 HP at the crank (don't know RWHP). It has a relatively mild Crane cam, 11:1 TRW forged with ported/worked 76cc stock cast iron heads netting about 10.6:1, converted 2-bolt center caps, and an old style Performer and POS Holley - no adders. If you're looking for that kind of power at the crank, it's very easy to do, since even I can manage it. For that level of RWHP, you may need some better components, but the extra cubes are going to be a big help in your quest.
Old Sep 9, 2002 | 08:43 PM
well hopefully I can pull it off... that is pretty much my goal for the car before the end of the winter
Old Sep 10, 2002 | 04:09 AM
Motopsyco's Avatar
Car: 89 firebird, 03 Avalanche z71
Engine: 5.0 stock (for now)
Transmission: 700R4 auto
Axle/Gears: stock 2.73 for now
hey vader
What cam ya got?, cuz id like around the same power ya got. What brand, and lift and duration?
--Stormr
84z96L31vortec
Aug 20, 2017 12:16 AM
86White_T/A305
Aug 17, 2015 12:16 AM
mustangman65_79
Aug 11, 2015 03:17 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
z28addict8490
Aug 7, 2015 08:48 PM
