Oil Pan / DipStick Question
Old Sep 9, 2002 | 07:37 AM
86FyrBrd's Avatar
Car: 1992 Camaro Z28 Convertible Z03
Engine: 383 SuperRam
For my engine build up its using an older, better, block, but its going in my 86 T/A, do I get an oil pan with the dip stick on the side my car had it originally, or what the engine had originally, or dont it matter, I just dont know if it would hit something.
Did our cars have it on the driver or passenger side originally (86 T/A) Motor is all ready out and apart so I cant check
Old Sep 9, 2002 | 07:43 AM
ede's Avatar
ede
you want the oil pan to match the block and the dip stick location
Old Sep 9, 2002 | 07:53 AM
86FyrBrd's Avatar
awwww sh**, how would I figure out what it had, I know its a 4 bolt main, 1 peice rear main seal block.
Old Sep 9, 2002 | 08:16 AM
ede's Avatar
ede
measure from the flat rails of the oil pan to the depth of the semi circle where it fits the rear and front and note the location of the dip stick hole. any oil pan for a one piece rear seal would work
Old Sep 9, 2002 | 11:18 AM
firechicken_3's Avatar
Car: 1984 Firebird
Engine: 350 Terminator EFI
Axle/Gears: 4.10
not to be an ***, but how hard is it to just look at the engine, even if its out of the car, you can still tell, seeing as how the dipstick passes through the edge of the block....
MoJoe
Sep 24, 2015 09:12 PM
Navy8125
Aug 21, 2015 09:32 AM
MY87LT
Aug 17, 2015 08:43 AM
matthew911
Aug 12, 2015 09:38 AM
gwade12
Aug 8, 2015 08:17 AM
