Ignition Wires and Headers
Old Sep 10, 2002 | 05:23 AM
mimgq2's Avatar
Hello-
What are some solutions being used to protect your spark plug boots. My boots are burning up constantly. The wires are fine and well routed. My boots are about ½ to an 1 inch from the headers. The boots that are an inch are ok the 4 that are closer burn up. My headers are not coated at this time. I will have them coated when it snows. Right now I want to run the car.
How are the Jacobs ceramic wires? They cost $181.00
How are the protector boots for $50.00
How are the wire protectors for $38.00, I thought this was good to preserve the wire longer.
My thought is that if I buy all the boots and protectors I might as well by the jacobs wires and be done. They practically cost about the same when all is added up.
Wires - $80 + Boot covers $50 + Wire Covers $38 = $168.00
How are the Moroso and or MSD replacement boots.
Again, My wires are fine. My boots are getting heat soaked then they crack. The wires are fine. Stubby plugs are not an option since they do not make them for AFR Aluminum heads.
What are other options.
Frank
Old Sep 10, 2002 | 07:34 AM
ede's Avatar
ede
i've used the nomax sleeves, can't be beat
Old Sep 10, 2002 | 05:56 PM
laiky's Avatar
I would say coating is the biggest step to boot longevity, i have coated slp 1 3/4 headers with AFR heads and there is very little clearance. I also run the Accell extream 9000 wires they have impregnated boots ( silver), after 4 months they are in like new shape. I also get the custom fit and route them with extream care and use dielectric grease in the boots to stop them from sticking.
Old Sep 10, 2002 | 05:57 PM
laiky's Avatar
also i think the Jacobs ceramic boots are rather large and may actually contact ( in my application ) the headers, i don't think it will work too well touching
Old Sep 11, 2002 | 05:29 AM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
MSD heat shielding works for me..
Old Sep 11, 2002 | 09:33 AM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
I'm using the Design Engineering plug wire boot protectors.
http://www.designengineering.com/
They sell all kinds of heat-insulation supplies.
Haven't lost a plug wire since installing them.
-Rich-
BRoss99
Aug 10, 2025 05:08 PM
Caspar
Jun 19, 2016 11:19 PM
Hellbillydeluxe
Sep 22, 2015 09:58 PM
Rakim_RS25TH
Car Audio
Aug 20, 2015 06:22 PM
Rakim_RS25TH
Aug 18, 2015 09:32 PM
