Need some help on if i have to change my distributor gear
Old Sep 12, 2002 | 01:41 AM
89ProchargedROC's Avatar
I have an 89 distributor from my original roller motor but i'm using an older block with a flat tappet cam that is brand new from comp....will i run into any trouble with the gear on the cam and the gear on the distributor?
thanks
Old Sep 12, 2002 | 04:58 AM
ede's Avatar
ede
you should be fine. you need to use a bronze gear when you run an aftermarket billet steel roller cam.
Old Sep 12, 2002 | 08:35 AM
thank you, can you take a look at my other post about the aftermarket oil pan?
eightsixseven
Dec 16, 2024 01:50 PM
jklein337
Sep 19, 2018 06:23 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
