Tach is way off!!
Old Sep 13, 2002 | 07:57 PM
84TransAm's Avatar
Tach is way off!!
Well, just got the 84 back from the garage today. Had a new clutch master cylinder/ slave cylinder setup installed. Mechanic also bypassed the "push to start" feature on the clutch. As soon as I drove the car, I noticed the tachometer was off by over 1000 rpm [high]. Any clues as to what might have caused this? Any help is appreciated.
Old Sep 13, 2002 | 08:06 PM
rocky383's Avatar
Car: 88 IROC-Z
Engine: 383 Stroker
Transmission: TH350
Maybe he dropped in a v10 to pull a funny on you?
:hail:IROC-Z
Old Sep 13, 2002 | 09:08 PM
84TransAm's Avatar
at first i was thinking 4.10's. But in all seriousness, I have no clue what is up.
Old Sep 15, 2002 | 07:41 AM
Z's r Best's Avatar
Car: '86 IROC, black and sharp
Engine: 305 tpi, bone stock
Axle/Gears: 3.42 pos w/rear db
Couldn't begin to tell you how to fix the one you've got. I've seen 2 bad ones so far (both read higher than true engine rpm) and we just installed junkyard replacements (their pretty cheap and common still).
Old Sep 15, 2002 | 12:10 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Mine reads fine at low rpm's and low at high. I got a number from the local stealership. It's a place that calibrates tachs. I haven't called 'em yet but plan to.
ATR Intern.
800.232.3965
Old Sep 15, 2002 | 08:24 PM
laiky's Avatar
first verify with another tach that yours is wrong, I recently saw the tach in my brothers HO go wacky, it was the pickup and modual. his was jumping around and his car began to misfire and was hard to crank with wayy advanced timing, even though the static timing was fine. Do you hear any pinging when you accellerate?? it could be the modual and pickup.
$750 L98
Feb 1, 2025 02:25 PM
86maro_252
Oct 10, 2015 06:52 PM
Eric-86sc
Sep 28, 2015 11:37 AM
RedLeader289
Sep 23, 2015 06:50 AM
TrevinE
Sep 14, 2015 03:20 PM
