how much HP can the stock 400 take?
Old Sep 14, 2002 | 03:41 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
I know it is cast but, so are stock 87-92 350 ones right?
Old Sep 14, 2002 | 03:45 PM
Engine: ls1, LB9
oops, I mean the crank and rods
Old Sep 14, 2002 | 04:15 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Yes, the crank and rods on all 400s are cast. Its not really the power of a 400 that you must worry about, its the RPM. 400s are not good revving engines due to the long stroke. Even with forged rods and crank, I still would not recommend more than 5500 RPM. 400 connecting rods are weaker than 350 ones due to the larger crank journal size.
Old Sep 14, 2002 | 06:12 PM
Engine: ls1, LB9
well, I don't want more than 5000 rpm out of it so I should be fine right? I think 350 to 375 max hp is what I will be making these are real hp numbers not fast and furious numbers
Old Sep 14, 2002 | 09:42 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
A friend of mine has a 700+ hp 400 small block.
It's in a 9 sec drag car.
He runs the factory cast crank to 7000+ rpm
Total reliability
He had the crank "Iced" (cryonic heat treat)
Old Sep 15, 2002 | 09:57 AM
zippy's Avatar
Car: 2006 Silverado 1500
Engine: 5.3L
they'll handle about all you want to throw at them. the two bolt blocks are generally stronger though. may of my friends that run circle track turn them 7k plus for 15 minutes or more at a time. just use good rod bolts and main studs along with a good balance job and you'll be fine.
Old Sep 23, 2002 | 11:05 PM
Mr_Happy's Avatar
450-550 HP just don't wing the pee out of it 5500 Max use a rev limiter MSD 6A etc... After market parts billet crank, concreted block, racing pistons and splayed caps it will hold around 1200HP.
Below Average J
Members Camaros
23
Nov 18, 2015 10:03 PM
Genopsyde
Oct 7, 2015 08:35 PM
camaro71633
Sep 1, 2015 10:24 AM
lakeffect2
Aug 23, 2015 08:44 AM
