Fuel return line... real quik Q
Old Sep 14, 2002 | 11:27 PM
Kingtal0n's Avatar
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
Sorry this is important or I cant finish this project...
quik: got Holley Pro-jection commander 950 TBI system.
Problem: Requires Fuel Return Line to gas tank
Question: '83 Z-28 Crossfire originally. Does this thing already HAVE a fuel return line I can just hook up to? Or do I hafta drop the tank... Ughh...
Old Sep 15, 2002 | 01:15 AM
89firechicken's Avatar
not to sure about the crossram but in your engine compartment you should have two steel lines going to your intake from the tank one as a return and the other as a main and the should be side by side as well but some one correct me if im wrong. now i have the problem of not knowing which is which so what im going to do is put a cup under both lines and prime my fuel pump and whichever sprays gas everywhere that should be the main.
Old Sep 15, 2002 | 06:37 AM
ede's Avatar
ede
larger line is supply and smaller is the return
Old Sep 15, 2002 | 12:07 PM
Kingtal0n's Avatar
Transmission: 4l80e
Axle/Gears: 3.512
Ack im sorry you misunderstand... I dont HAVE crossfire its a blown/carbed 355 now, but im adding TBI to the blower and need a return line... Where would it be? I found the fuel feed line.. I use it to feed my carb! but the return line?
I see another line running down the driver side to the very front of the car where the CHARCOAL box thing used to be... Is this it? It smells like fuel... and the EGR picture shows it going to the gas tank....
if thats not it... then ill keep looking.. thanks for the help...
My car: http://www.geocities.com/kingtaling
you can see what Im talking about!
Old Sep 15, 2002 | 03:39 PM
well i guess your best bet is to trace the lines from your gas tank to up front, there should be two going up front and four total at the tank. hopefully that helps.
Grant2k
Jul 10, 2018 04:01 PM
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
wayshegoes
Aug 17, 2015 12:00 PM
TEDSgrad
Mid-West Region
Aug 10, 2015 07:12 AM
Kaweh
Aug 9, 2015 02:54 PM
