Please help, fuel question
Old Sep 15, 2002 | 04:05 PM
j_bonham69's Avatar
Ok i have an 89 tpi 305 trans am. it broke down and i tried to start it and it wouldent. i sprayed carb cleaner into it and it started. i thought it was the fuel pump so i replaced it. after i replaced it i tried to start it and it still wouldent start. it still fires on carb cleaner.i have fuel pressure and i hear the pump cycle when i turn the key. also the inertia switch is down. what else could it be????? please any suggestions will help.
Old Sep 15, 2002 | 04:09 PM
j_bonham69's Avatar
it only stays running when i continuously spray cleaner into it if i stop it dies.
Old Sep 15, 2002 | 04:25 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
fuel filter, "ecm" fuses in the fusebox
Old Sep 15, 2002 | 04:40 PM
j_bonham69's Avatar
if it was the ecm would it still start on carb cleaner? also i checked the fuel filter i'ts not plugged.
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
fasteddi
Sep 2, 2015 10:29 AM
redmaroz
Aug 16, 2015 11:40 PM
