Coil? Pick up Coil? Please explain
Old Sep 15, 2002 | 06:54 PM
bzznczzn's Avatar
Hey guys I have an 87 Formula 350 and just found out i have a bad coil. Do our cars have coils and pickup coils or is that just some termanology? Please explain. I just replaced what I thought was the coil (where the coil wire leads from the distributer) and found out that was my problem. I was borrowing the part off of a neighbors car to see if it worked and it did. When i go to buy one, what do i ask for? A coil or pickup coil? ANy help would be greatly apreciared
Old Sep 15, 2002 | 08:04 PM
Vader's Avatar
The coil you are describing is teh ignition coil. Your car also has a pickup coil in the base of the distrributor that works in conjunction with the reluctor to create a small electrical impulse to trigger the HEI module (next to the pickup coil) to operate the ignition coil.
There is a fairly reasonable explanation of the system in most manuals and at the AC/Delco site:
http://www.weekendmechanicsclub.com/ACDelco/vobeng5.htm
MM2Robinson
Oct 1, 2017 09:16 AM
timonator
Sep 17, 2015 06:57 PM
Jlanz55
Sep 6, 2015 03:05 PM
Jlanz55
Sep 6, 2015 02:35 PM
