Engine's strong at WOT, uneven at part
Old Sep 16, 2002 | 01:10 AM
Rob116's Avatar
Car: 1986 Z-28 Camaro
Engine: 355
I've set the timing on my '81 350 at zero, as recommended, rebuilt my carb and at WOT, my '86 is running pretty damn strong. Unfortunately, when I stay out of the four-barrel (CC Q-Jet), the engine seems to lurch a bit and just generally runs a bit unevenly.
Could it have something to do with the tampering with the set-screw that occurred when I adjusted the A/V? Any other suggestions? I just replaced the TPS as well.
Old Sep 16, 2002 | 07:44 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Sounds like the primaries are too lean... nothing you can do to the secondaries, or have already done like the AV, will affect that.
Try adjusting the idle air bleed valve in, in about ¼ turn increments, see if that has any effect.
Azrael91966669
25
Jun 20, 2017 04:04 AM
lakeffect2
Aug 23, 2015 08:44 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Armored91Camaro
Aug 12, 2015 09:41 AM
1nastygta
Aug 8, 2015 07:38 PM
