Is it possible to re-drill axles for a new bolt pattern yourself??
Old Sep 17, 2002 | 05:55 AM
ChrisFormula355's Avatar
Car: Junk
Engine: Junk with nitrous
Transmission: Junk with gears
I just got a 10 bolt 8.5 3.42 posi rearend from a Caprice for my grand prix..........everything bolts up fine besides the fact that the rear is exactly 2 inches wider........but the bolt pattern is 5 on 5!! A friend said you could use a rim to make a template, and simply drill the hole yourself and install some studs. what do you guys think? Anyone try it? I guess the only other option is new rims...........NOT!
Old Sep 17, 2002 | 09:18 AM
ede's Avatar
ede
i wouldn't be afraid to do it. you'd want a drill press so you could have the flange flat. i'd use a divider to mark the circle and then use the divider to maker the hole spacing and not try to transfer the holes from a wheel. you'd have to know the diameter of the splined section of the stud and drill the hole to match it.
Old Sep 17, 2002 | 07:30 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
n/m my mistake
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Jorlain
Oct 8, 2015 01:57 AM
dbrochard
Oct 3, 2015 12:43 PM
rudolphschenker
Sep 4, 2015 02:41 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
