do i need a higher stall converter
Old Sep 17, 2002 | 04:03 PM
TunedPortZ's Avatar
ok ive had my cam in for about a year now, and i just started wondering if maybe i needed to step up the TC stall? what do you guys think , it is a 423/446 lift crane cam, and everything else i have is in my sig. if so, what is a good quality not exspensive TC and what stall should irun.
Old Sep 17, 2002 | 04:06 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
You don't need a stall with that cam, but it sure will help a lot.
For a daily driver I wouldn't go above a 2800 or so, from what I've read. Basically, you want a stall 500 rpms below your peak tq if I recall correctly. But that in some instances will still be too high for a street car.
Old Sep 17, 2002 | 08:26 PM
TunedPortZ's Avatar
thats what ive been told is about 2800 but i was thinking about 2400-2500 because TPI has nothing above 5000 rpm. any advice on the brands to get?
Old Sep 17, 2002 | 08:33 PM
Bort62's Avatar
precision industries Vigilante.
there is no Substitute
ps Make sure your sitting down when you Get a price quote )
Old Sep 17, 2002 | 09:07 PM
rezinn's Avatar
Good advice from these guys. What is the duration on that cam? That's more important than the lift numbers because duration determines the powerband and where you'll make max power.
Old Sep 17, 2002 | 09:09 PM
Car: 99 Formula
Axle/Gears: 342
again, i sit corrected.
Old Sep 17, 2002 | 10:42 PM
TunedPortZ's Avatar
204/214 i believe
Hotrodboba400
Dec 10, 2019 07:07 PM
89fast5oh
Sep 8, 2015 09:55 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
masonta
Sep 1, 2015 06:40 PM
