Need advice.
Old Sep 17, 2002 | 05:21 PM
Firl's Avatar
Need advice.
ok I am in college and Did not know if there was anything that I could put on to my 305, to boost the Horsepower, as well as fit on a 350 5.7 liter which i plan to switch to later.
Im just looking to add a lil kick to my car, that would be feasible to do in the schools parking lot.
thanks for the help in advance
Old Sep 17, 2002 | 06:22 PM
Kevin Johnson's Avatar
If you have a TBI, put in either an open element filter or the "truck" type higher aircleaner lid. Both are fairly cheap and will give you a little boost in power.
Old Sep 17, 2002 | 07:03 PM
Firl's Avatar
I have an CC quadra jet Carb ... should i just go out and grab an K&N air filter?
Old Sep 17, 2002 | 07:13 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Good idea, or get the HO dual snorkel air cleaner.
If you can swing headers that would be a good idea.
Old Sep 17, 2002 | 09:23 PM
Firl's Avatar
Do you know how much HP I would gain doing either? because it seems a lot of money just buying an air filter ...
Old Sep 17, 2002 | 09:29 PM
Car: 99 Formula
Axle/Gears: 342
You might get 5hp from the KN at most, maybe 2-3hp, the dual snorkel would get you a little more.
the headers would be a 15-20hp gain estimated.
Old Sep 17, 2002 | 09:34 PM
rezinn's Avatar
Almost anything you buy for your 305 will physically bolt onto a 350. A K&N filter is a good investment because you'll never need another filter, you'll just need to buy a $12.00 kit next year to clean it. That kit will last a long time, too.
Old Sep 18, 2002 | 12:38 AM
Firl's Avatar
What if I were to make an cold Air Intake for my carb ... thats possible right? maybe even dual cold air ? any flames before i even think about it?
Old Sep 18, 2002 | 01:01 AM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
Look for one of these in the boneyard. Just concentrate on getting parts that you can use on your 350 later, like exhaust - intake - or even an open element air filter. Peace
gord327
Sep 29, 2015 10:18 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
KCG
Sep 23, 2015 09:05 AM
mrdevontay
Sep 2, 2015 08:04 PM
transamgta87
Sep 1, 2015 07:07 PM
