Underdrive Pulleys
Old Sep 21, 2002 | 04:40 AM
zerotosixtyV8's Avatar
Car: Camaro
Underdrive Pulleys
I am planning on putting smaller underdrive pulleys on my car and I need to know how to tighten, loosen the belt tensioner so that I can get it off. I know it's spring loaded and I don't want this thing to fly off at me or cause damage to the car, belt, or myself. is there a special tool required for doing this?
Old Sep 21, 2002 | 07:07 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Turn it in the direction of tightening it.
Old Sep 21, 2002 | 12:18 PM
Guest
Guest
Posts: n/a
There should be a square hole in the tensioner. Stick a 1/2" breaker bar preferably or rachet in there and twist it out of the way. You'll need to push the breaker bar over to the passenger side of the car.
Dont mess with the bolts on the tensioner. Bad idea.
Old Sep 21, 2002 | 03:23 PM
Car: Camaro
thanx. Also, I hear that underdrive pulleys don't have a harmonic dampener and this can cause engine damage in the long run? Is this the case with Camaros? or do kits come with dampeners?
Old Sep 21, 2002 | 03:55 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
no they don't come with a dampner. you use your stock one. all you are doing is changing the pulley bolted to the balancer.
Old Sep 21, 2002 | 06:13 PM
Car: Camaro
alright, I've heard some cars pulleys have the dampener in the pulley itself. this is not the case with the camaro, thanx a bunch
Old Sep 22, 2002 | 09:18 AM
mrr23's Avatar
Engine: 360 HSR
yep. the LS1 engines have the dampner/pulley design. in that case you would get a new balancer.
grngryoutmyway
Oct 18, 2016 05:48 PM
bigjay89gta
Oct 15, 2015 08:04 AM
jaridjohn
Oct 5, 2015 07:01 AM
anesthes
Sep 30, 2015 07:48 AM
JSDaddy189
Sep 26, 2015 03:50 PM
